Machine Vision
Array of images into single Access database field
Hello all,
I have this pie in the sky idea to save an array of images to a single Access "Memo" datatype data field by constructing a string using three functions:
1) "IMAQ Flatten Image to String.vi"
2) "Array To Spreadsheet String.vi"
3) "Spreadsheet String to Array.vi"
First I construct an array of strings containing images that have been flattened using the "IMAQ Flatten Image to String.vi".  Next I take the resulting array and use the "Array To Spreadsheet String.vi" to create a single string that is than inserted into an Access "Memo" database field.  Labview has no problem storing and retrieving the data from the "Memo" format as a string, the problem is when using the "Array To Spreadsheet String.vi" the data becomes corrupt.
I have also thought about ZIPing the image directory and storing it into the database as an "OLE" type.  I can zip the images fine but do not know how to load the zipped result into labVIEW 2010 and then push it into ACCESS,  the images are small, only ~50KB
Cheers,
Karl
(3,383 Views)
The flattened string of the image contains non-printable characters and might not be compatible with limitatious of the spreadsheet format. Perhaps you could use Base64 encoding on the string first?
Eric
(3,376 Views)
Hi BlueCheese,
Thanx for the reply.
Actually I figured out what to do just after the post.  I simply concatenate a fiducial after each string image and then concatenate all images into a single string (see attached code) and then reverse the process reading back from the database, works perfectly.
Karl
(3,356 Views)
