Machine Vision
Asynchronous triggering of pulnix TM-9701with PCI 1422 Framegrabber
Hi
I am currently trying to synchronise the aquisition of images from a pulnix TM-9701 camera to an event that runs at 25Hz, I am able to take a triggering signal with the PCI 1422 digital framegrabber card that I have and I would like to use this card to send the trigger signal to the camera to tell it when to reset in asynchronous reset mode. I have identified that there is an output pin on the card [Control 0+] that is connected to the Vinit line on the camera which controls the asynchronous reset but I don't know how to send this signal to the camera using the framegrabber in labview.
thank you for reading this post
Omair
Message 1 of 1
(3,058 Views)
