Machine Vision
BP Evaluation Score
We are working on a machine learning system using the machine learning toolkit. We are using the BP Learn VI to calculate a solution to our classifications of images.  Then at runtime we can run images through the BP Eval VI to get a classification out.  What we are struggling to understand is how to get some sort of score for the output at runtime. When we do the learning there is no "Unknown" but it seems that if I run an image through that is nothing like any of the learned images it should be "Unknown".  Any information on this front will help. Thanks.
(3,739 Views)
Hi jesserzamora,
I would recommend posting in the comment section on the NI Community page you linked. By doing that the developers may be able to help you.
Best Regards
Kale W.
(3,711 Views)
