Machine Vision
NI Vision Builder: calculating orientation of the component relative to the first image in degrees
Hi all
I have a query regarding a component of an aircraft. There's 9 images of the component with and without defects. I would like to kindly request for some guidance to calculate the orientation of the component to the first image in degrees*.
All advice will be gratefully appreciated.
Thanks guys
PS: if you require further detail, please let me know and I will extend my post.
Message 1 of 14
(5,075 Views)
What version of VBAI do you have?
Have you taken a look at the examples?
Depending on what shape is the component you're observing you have different strategies available to you to calculate orientation, can you show your images?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 14
(5,063 Views)
send your image i think it is easy peasy thing
I will send you vi to use just give some information about your resolution
Message 3 of 14
(5,052 Views)
There you go guys..
Please advice me of the steps needed to be taken to calculate the orientation.
Thanks all 🙂
Message 4 of 14
(5,045 Views)
you know ther is several method to find orientation I point some of them
1 optical flow
2 find specific object in image and try to pattern match or geometry matching or color pattern matching
3 use ssim mechanical operators
Message 5 of 14
(5,039 Views)
1 optical flow
Yes, Hatef. I would like to know how to take the second approach please where you have to find the specific object and try to match. Thanks for your advice!
Message 6 of 14
(5,036 Views)
you can do it manual means select some particle that are detectable by color or intensity or shape
otherwise you can use so,e ,method like histogram to analysis where is the object to make it template for this propose
Message 7 of 14
(5,032 Views)
Will you be able to explain it further step by step please? New to vision builder and I'm still getting my head around how it works.
Message 8 of 14
(5,030 Views)
i am going yo home now there i do not have Internet access tomorrow I will send you some example vi
but it is better send at least one of your image to analyze
Message 9 of 14
(5,028 Views)
Yes, an example should do. Thank you! I look forward to hearing from you soon! The pictures to analyze are attached above
Message 10 of 14
(5,019 Views)
