Machine Vision
Basler AcA64-750µm not recognized after switching driver to NI-IMAQdx USB 3 vision device driver
I can grab video from the camera with the Basler pylon software. It is also recognized in NI-MAX but it tells me to switch to IMAQ Vision driver to use it. When I do that it vanishes from the list in NI MAX. I have to reinstall the Basler driver over pylon Software to make it visible again. Are there additional driver I have to install? I am running Windows 10, Labview 17.0.0, IMAQdx 17.1.0, NI MAX 18.5.0f0.
Best Regards
(3,503 Views)
Can you show screenshots of device manager after you've switched drivers? Can you find the device there?
(3,472 Views)
I attached the screenshot. When i disconnect the camera the USB3 Vision device vanishes from device manager, therefore I assume it is the camera  The device status states that the digital signature of the driver cannot be checked. Possibly a file might be damaged etc (code 52). Unfortunately I am running the german version of windows therefore I can't give you full english equivalent.
(3,415 Views)
Accepted by tobi_durrrrr
Thanks for the screenshot -- that explains it. Unfortunately the combination of IMAQdx 17.1 and Windows 10 results in this issue -- sorry you came across it! Here's a KB that describes it and makes recommendations: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9IFSA0&l=en-US
Ideally just upgrade to IMAQdx 17.5 (or later) and you should be all set.
Hope this helps,
Katie
(3,403 Views)
Updating the package resolved the issue. Thank you very much!
(3,376 Views)
