Machine Vision
Basler Lost Packets Can't Resolve
I have been trying to get a Basler camera working with Labview and MAX again.  I say again, because it use to work.  Not quite sure what happen other than upgraded to 2012 SP1 and the new Basler driver 3.2.  I went thru and followed Basler's instruction for driver install and network card settings.  Please check out the screenshot.  The weird thing for me is that it will have a steady image for three or four seconds, and then it starts losing packts and never recovers.  Why would it be able to keep up for a few seconds and then the problem?  I would assume if the setup wasn't right, it would never have a full image.  When I had this issue before, I was able to mess with the timing of the resend messages, and it solved the issue when running Labview 2011; but that doesn't seem to work now.
The screenshot is from MAX, but it acts the same in my Labview app.  When I run the Basler pylon viewer, it doesn't drop have any issues.  Any ideas?  Thanks.
(6,004 Views)
Are you using NI High Performance Driver for Intel NIC?
Please read the following kb:
Troubleshooting GigE Vision Cameras
Andrey.
(5,991 Views)
Looked over that document.  I am not having any of those issues.  I am using the Intel driver Basler recommends, and I have the jumbo frames maxed out. It will get images for a few seconds, and then it starts losing packets, and hence the lines in the images.
(5,985 Views)
Try to use Intel Driver NI recommends, not Basler.
(5,978 Views)
A few additional comments:
- You are using the standard Intel driver rather than the NI High Performance Driver
- You are using a PCI-based Pro/1000 GT rather than a PCI express card. Unless you happen to have this card in a 64-bit/66Mhz slot (fairly rare) then you are likely going to run into bandwidth issues. PCI only has 133MB/sec of bandwidth shared among all the slots while Gigabit Ethernet can consume 125MB/sec in each direction (250MB/sec combined), not including all the additional overhead the card needs to handle book keeping of the data.
I suggest replacing the Pro/1000 GT with a PCIe Intel NIC instead (such as the NI PCIe-8231). You also may be able to try adjusting the "Peak Bandwidth Desired" attribute in the acquisition attributes to allow throttling the camera to something <80MB/sec or so which should be much more robust on the limited bandwidth of PCI.
Eric
(5,954 Views)
Hi
Another thing to check is your cable. Be sure to use at least Cat 5E and try with different cables.
Regards
(5,944 Views)
I use Basler GigE with the Pro 1000 and the "National instruments GigE Vision" Driver.
Normally I use 2 or more cameras.
I test if hardware and driver is working well with MAX.
For each camera I start a new MAX and let the camera run in GRAB.
The cameras should all run at the max frames/second which the supplier specified.
I have done this in 8.6 and LV2012 DS2.
I let it run for a weekend. For each camera there are 6.000.000 Images taken. (30 frames/sec)
It should give zero Resend Packets Requested and zero Resend Packets Received and zero Lost Packet Count
If there are then you have to look at driver or hardware.
I install vision acquisition and do not change anything.
See pictures attached.
Notes:
- I never installed driver from Basler.
- When using software trigger instead of continuous grab there will be Resend Packets Requested. There should not be a lot of them and also NO Lost packets.
Toine
(5,890 Views)
