Machine Vision
Buffer extract for subtraction using IMAQdx or IEEE1394
Hi all,
              I want to implement extracting a particular buffer in IMAQdx as in IMAQ. I found that IMAQ palette has buffer configuration.vi and buffer extract extract. vi in low level vi sub palette.
I could not see the same feature in IMAQdx or in legacy IEEE1394 palette. I desperately need to implement subtraction for motion detection, is there any way to implement???
I am using LabVIEW 8.2 with IMAQdx 2.0.4 version. I have attached  the vi which was implemented for IMAQ for analog camera and was working properly for motion detection.
I have also attached similarly implemented vi in IMAQdx for IEEE1394 digital camera and is not working properly.
Any help would be invaluable to me.
(3,433 Views)
Just to simplitfy the problem, using IMAQ1394 get image.vi can i extract particular buffer????
Just have a look at the attached image.
Sorry for confusing with my complicated question in the previous post..
(3,396 Views)
Hi Viswa,
Have you tried looking at the examples contained within the NI Example Finder which relate to IMAQ1394? These can be found at Hardware Input and Output » IMAQ1394 (or IMAQdx). This KB refers to an example which may illustrate how you can extract a particular buffer.
I hope this helps.
Best Regards,
Christian Hartshorne
NIUK
(3,363 Views)
Hi Hartshorne,
                             I finally used IMAQdx get image.vi to extract a particular buffer instead of legacy IEEE1394 getimage.vi. Now it looks like i can do image processing.
Thank you for your help.
(3,357 Views)
