Machine Vision
How can I use the zooming tool inside a loop?
How can still use the zooming tool inside a while loop? The attached .vi shows an example how I would like to use the zooming tool after I opened
an image. Unfortunately the zooming tools can not used as long the loop is active.
The output of this example has no meaning  ...
regards
(3,485 Views)
Can you post a screen shot?
(3,477 Views)
and with a screenshot...
(3,475 Views)
Hi Norick,
In your "start" event has the screen locked while the event is running. Simply go into edit event and uncheck the box that says lock screen.  It may not say lock screen but something similar - I can't remember the exact words. Anyway I tried this and it worked OK.
Regards
Simon
(3,455 Views)
Here is a screen shot of what I mean. It was the lock front panel check box I was refering to.
Simon
(3,454 Views)
