Machine Vision
IMAQ-USB- brightness change
I'm using IMAQ -USB and associated VIs to grab images from webcam. I need to modify its brightness programatically. I was thinking about using property nodes to modify the brightness. However, I see that option is not available. Any inputs how to modify the brightness while I'm grrabing images and displaying it on VI?
Thanks.
ABM
(3,577 Views)
What is the camera that you are using? Will using a BCG look up after acquire put in a while loop solve the issue?
(3,576 Views)
As I mentioned in follow up post that  BCG look up after acquire put doesn't help. Hence I added new post with the attached VI. Thanks
(3,548 Views)
You can continue in onethread to have a better response right?
(3,546 Views)
(3,543 Views)
