Machine Vision
CVS 1454 memory
Hi all,
I'm wanting to upgrade an old CVS 1454's memory. Are these compact flash cartridges compatible? And is there a limitation to the size I can use on a 1454?
Jevon
Message 1 of 11
(5,188 Views)
NI CVS-1454 Memory Upgrade
Message 2 of 11
(5,188 Views)
I have already viewed this document, but our customer is wants to know if he can just buy a memory card and just make the swap himself.
Message 3 of 11
(5,186 Views)
I feel it is better to contact your local ni rep.
Message 4 of 11
(5,180 Views)
Thanks Muks,
I have contacted them. Although if you do know the memory size limitation on the 1454, that would be interesting to know.
Thanks.
Message 5 of 11
(5,173 Views)
Hi JChec,
I am investigating.
Jeff | LabVIEW Software Engineer
Message 6 of 11
(5,158 Views)
Hi JChec,
I'm still not sure what the 'maximum' is, but one of my coworkers has used 512 MB in one before. If I hear a higher number from R&D I will let you know.
Message 7 of 11
(5,125 Views)
Hi again,
I would like to point out that this is NOT a supported upgrade process and will void the warranty, so it may be moot.
Message 8 of 11
(5,122 Views)
Hi Jeff,
Thanks for the response. I understand this will void the warranty and is not a supported upgrade. Our customer has had this CVS for years so the warranty doesn't apply in any case.
Jevon
Message 9 of 11
(5,103 Views)
Hi Jeff,
I see the is a large difference in prices between 512MB and 1GB. Any news from R&D about whether 1GB can be used?
J
Message 10 of 11
(5,085 Views)
