Machine Vision
Bug - In circle detection Vision assistant
Check the Image below.
I am using Vision assistant 8.0.
Message 1 of 8
(4,902 Views)
Interesting (wrong) results.When the lower limit is increased to 40 I get 3 circles and 50 gives a proper output. I used this image.
And the attached script file.
Message 2 of 8
(4,901 Views)
Can some one reproduce this and file a CAR?
Message 3 of 8
(4,868 Views)
Can you tell me which version of Vision Assistant are you using. I tried to replicate the issue at my end but it is working fine. I used Vision Assistant 2009.
Hardik Asawa
Message 4 of 8
(4,844 Views)
I am using 8.0...Known issue?
Message 5 of 8
(4,840 Views)
Were you able to open the scr? Did you apply the same threshold?
Message 6 of 8
(4,837 Views)
Yes I ran the same script with similar thresholds seems like some issue with previous version software.
Message 7 of 8
(4,795 Views)
Ah one more reason for me to push for the upgrade.........:smileyvery-happy:
Message 8 of 8
(4,791 Views)
