Machine Vision
vision
I am a new user of vision assistant and of treatment image.
With a microscop I acquire a image of nanoparticules.
And now I want to treatment this image with labview.
The goal of this treatment and to know the distribution of size.
The particules are a ellipsoide form, so I must know the long side and
the short side. When I know the size of the two side, I calculate distribution of
size and the ratio.
I begin to work with vision assistant and now I work with labview.
I have some problems.
The first is :
The programm analyse only a part of image. The part is show in image out in front panel, the rest
of image doesn't analyse. Why?
the second is :
I use the fonction Particle analysis for to now the
equivalent rect long side and the equivalent rect short side.
Until now I work in pixel but I want to work in real world.
The particule measurements doesn't work but I don't know whty
Do you have any suggestion?
PS : I know, that the particules are stacked. At the end of the programm I put a max limit and min limit
to eliminate the stackparticules and the scrap.
(5,772 Views)
First please attach a jpg image and dont rename a bmp image as jpg. The image is still trying to load here. Since the overlapped/stacked particles can be ignored, You can consider the area of the particle for this. Using a realworld measurement requires you to calibrate the dimension measurement. One simple way you can try is to manually calculate the number of pixels with mm.
(5,770 Views)
The problem with the jpg is the microscop give a tif format image. And I don't can to download a tif image in this forum.
Sorry I don't think it can't make problem if the image is in jpg instead in tif.
(5,766 Views)
Any update?
(5,686 Views)
Yes, I have some improvements.
But I don't know to calibrate my image.
Do you know to calibrate an image ?
I try with the fonction "IMAQ select Point" two times and then
with the fonction "IMAQ Point Distances"? but I don't know
if it exist a best solution?
And I have an another problem.
After the fonction "particule analysis" I have a 2-D array, and after
I want a txt file with the measurements. For a 1-D array I know to convert into string
but for a 2-D array I have some difficulties.
Tanks for your help
Aurélie
My image
http://www.filedropper.com/v2271
(5,683 Views)
Use a reshape array and get the required elements out of a 2D array.
(5,664 Views)
Check these examples [broken link removed]
(5,662 Views)
