Machine Vision
CCTV camera security
which security systems are good for offices or institutions.
I also need to know about recording systems.
(5,308 Views)
Generally these discussion forums are used to assist in troubleshooting issues with National Instruments products.  This particular board is meant to aid machine vision applications with either helping users develop/debug software or troubleshoot camera/hardware setups.  Do you have an idea of what sort of cameras you intend to use? Do you plan on using NI Drivers or perhaps developing in LabVIEW?
Isaac S.
(5,289 Views)
The choice is so wide, it is necessary to know in details what do you want your system to do, do you need a constant live stream from cameras, or just recording when movement is detected....and so on.
But I personally use Xeoma video surveillance software and am more than happy with it. It is powerful, AFFORDABLE, user-friendly and they have great support (which is veeeery important).
(5,115 Views)
In CCTV Camera there are various different qualities available, So, please suggest me which one should I purchase and From where should I purchase.
http://www.hotelsafes.com/
(4,967 Views)
Hi Deonshook,
-Please see that thread was inactive for around 2months 🙂 Better start new thread.
-You need to first know and explain what are your requirements, then people can give better suggestion.
uday
(4,949 Views)
