Machine Vision
CVS & AVT F-131B
Dear Engineers.
I got a CVS 1454 and, AVT F-131B,
When I connect camera AVT F-131B and CVS, but I couldn't find camera in my max.
so, I tried 2 kind of  tests.
First, I connect camera AVT F-131B at my computer, and I find my camera in my max,
Second, I connect other cameras (AVT F-145B2, 033B) at my CVS, and I find my cameras in my max.
Why can't I connect AVT F-131B and My CVS,
Please answer about my question.
My System is NI-Imaq for IEEE-1394 Driver V2.0
                      Vision Builder A.I. V2.6
Thank you.
(3,554 Views)
Does the CVS recognize your camera? You will be able to tell when you reboot your CVS with the camera plugged in - on the monitor connected to the CVS you will see if it recognizes any devices attached to the 1394 bus. If it says that there is 1 device connected, then it is recognizing your camera and there might be a network communication problem between MAX and the CVS. If it shows 0 devices attached, then I would try formatting the CVS and reloading all the software and trying it again.
Let me know what you find from those tests.
(3,544 Views)
Dear Sir.
Thank you for my question.
but, I connected camera F033B (there is acting well) with My CVS,
I can't find it said that there is 1 device connected at CVS's Monitor.
I found the message followed,
" Found OHCI Compliant IEEE1394 driver.......
Bus1, device 10, function 0......"
so, Please tell me, how to check it again.
Thank you for support My work.
(3,537 Views)
If you do see the message:
" Found OHCI Compliant IEEE1394 driver.......Bus1, device 10, function 0......"
on your CVS, then it is detecting your camera. The problem could be with the communication between your CVS and MAX. Have you tried to format the CVS and re-install the software?
If that does not work, try un-installing and re-installing NI-IMAQ for IEEE 1394 driver on your PC and then also reload the software on the CVS.
Un-installing and re-installing driver software often fixes strange problems like you are seeing.
(3,528 Views)
Thank you,
I solve my problem,
When I download NI-Imaq for IEEE1394 V2.0.1, and I install it,
then, catch my camera in CVS.
(3,524 Views)
