09-27-2005 02:22 AM
09-27-2005 05:52 PM
Does the CVS recognize your camera? You will be able to tell when you reboot your CVS with the camera plugged in - on the monitor connected to the CVS you will see if it recognizes any devices attached to the 1394 bus. If it says that there is 1 device connected, then it is recognizing your camera and there might be a network communication problem between MAX and the CVS. If it shows 0 devices attached, then I would try formatting the CVS and reloading all the software and trying it again.
Let me know what you find from those tests.
09-28-2005 04:07 AM
Dear Sir.
Thank you for my question.
but, I connected camera F033B (there is acting well) with My CVS,
I can't find it said that there is 1 device connected at CVS's Monitor.
I found the message followed,
" Found OHCI Compliant IEEE1394 driver.......
Bus1, device 10, function 0......"
so, Please tell me, how to check it again.
Thank you for support My work.
09-28-2005 05:24 PM
" Found OHCI Compliant IEEE1394 driver.......Bus1, device 10, function 0......"
on your CVS, then it is detecting your camera. The problem could be with the communication between your CVS and MAX. Have you tried to format the CVS and re-install the software?
If that does not work, try un-installing and re-installing NI-IMAQ for IEEE 1394 driver on your PC and then also reload the software on the CVS.
Un-installing and re-installing driver software often fixes strange problems like you are seeing.
09-29-2005 07:02 AM
Thank you,
I solve my problem,
When I download NI-Imaq for IEEE1394 V2.0.1, and I install it,
then, catch my camera in CVS.
