10-20-2009 02:21 AM
Does anyone know the feasability of using Machine Vision or LabView to calculate the number of fringes in each region? (Image attached). I want to count how many white line on each region. For example, on attached image, there is about 6 regions, and each region will display the number of white line of their own region. For the information, I have LabView V8.5 and NI Vision Assistant V8.5. Please, give me some ideas on how to solve it.
Thank you.
Farid
Solved! Go to Solution.
10-20-2009 02:31 AM
You can use a simple edge detection like this
10-20-2009 02:35 AM
10-20-2009 03:19 AM
10-20-2009 04:18 AM
Hi muks,
1) Thanks for the quick reply. I've done the simple edge detection. Yes, I am able to count the number of white line by applying edge detection. But, I want to determine the number of line for all the region automatically. Is there any way that I can do that without draw a single line?
2) Thanks for the fringes.vi file. I can run this VI, and it produces 7 particles from the image that I posted before. That is good. Btw, how to count the white line of each particle? The output that I'm looking for such as : Particle 1 = 10 lines. Particle 2 = 12 lines. Particle 3 = 7 lines. and so on.
3) I am not understand what do you mean by 'Feed the output of this particle analysis bounding box (Top,Left,Bottom,Right) to the edge detection region of intrest and adjust the settings accordingly'. Could you elaborate more detail please.
Farid
10-20-2009 04:39 AM
10-20-2009 05:18 AM
Thank you so much.
This VI is really help.. I think I've got the idea to solve my problem.
Farid
10-20-2009 05:56 AM
