Machine Vision
Calibrate Image - Dialog
Hi all!
There is a very usable dialog in Vision Assistant called : Calibrate Image.  I would like to ask, how should I call this dialog from my LV code with some parameters?
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,955 Views)
You cant call vision assistant from labVIEW. You can simulate one though.Can you try what you wish to do in the dialog?just view?
(3,932 Views)
This is the dialog what I want to call from LV. Is it possible?
[Hungary]
(3,924 Views)
Accepted by D60
Atleast I am sure calling this dialog in lv is not possible.
(3,908 Views)
