Machine Vision
Camera failure after upgrade to IMAQdx 4.0
after upgrade, my Genicam compliant cameras stopped working with IMAQdx 4.0 with error message:
Error Code = 0xBFF6901D: Unable to load camera's XML file.
the cameras are Net-gmbh GO124 and GO432. They worked well with earlier software.
Tried rebooting, restarting cameras and removal of all related files from C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data .
If all else fails, please advise how to downgrade.
BR;
Jussi Larjo
(4,658 Views)
More information of the above: IMAQdx loads a XML file provided by the camera. Nothing appears to the PreProcessedCache, however. Attaching the XML file for reference.
(4,657 Views)
XML file zipped.
(4,656 Views)
Hi I have the same problem with a Net gmbh cima GO134c. Did you solve the problem?
(4,522 Views)
Accepted by Jlarjo
Yes, you can ask for firmware update from net-gmbh. s.wunderlich at net-gmbh.com
(4,520 Views)
It worked thanks Smiley Happy
(4,483 Views)
