Machine Vision
Camera image as local variable
Hey,
I am looking to use the same image out reference for each of my camera inspections. I take an image at the start of my test i call this camera image1, later on i perform numerous test inspections, however, my camera1 image is blank for the first 5 steps but displays an image for 3 steps then gives a blank image at the end again. I created a local variable of the image out reference. Any suggestions helpful. Thank you.
Damien
(3,949 Views)
Hi Damien129,
Are you able to upload your VI here for me to take a look at.
Something to bare in mind is that the value from image out is not an image. The value is a refernce to the temporary memory location where that image is stored.
Kind Regards
Kevin R
Applications Engineer
National Instruments UK&Ireland
(3,938 Views)
Accepted by Damien129
Hey,
Thanks for the interest i solved the problem, reson why the image would not appear at the output of my vision assistant express vi was because i never restored the original image.Thanks again.
Damien
(3,927 Views)
