Machine Vision
Can I install more than one PCI1409 in a PC
I have to capture two RGB sources for identical treatment. Can I install more than on PCI1409 in one PC ? Is there a limitation of the number of cards ?
(2,884 Views)
You can install multiple cards in a single computer. The main limitation is bandwidth of the PCI bus. I am not sure exactly what that limit is, but I don't think you would have any problem acquiring two RGB signals at normal rates.
If you have to process the images as you acquire them, you could run out of processing power, though.
Bruce
Bruce Ammons
Ammons Engineering
(2,884 Views)
