06-04-2011 03:41 PM
I know there are hardware solutions (RTSI based and trigger based) to synchronize starting image and analog acquisition.
For reasons, I cannot use hardware solution. So now I would like to find software solution to start the two acquisitions simulnateously.
And rely on the fact that both camera+framegrabber (PCIe1433) and DAQ cards (PCI 6251) has microsecond (better) accuracy.
So if I can start the two acquisitions simulnaneously, I can assume that with millisecond accuracy (limited by windows OS) I will have the images (100Hz) and DAQ signal (50kHz) synchronized till the end of acquistion.
(A) Am I right ?
(B) Now the part 2 of my question is whats the best method to software-trigger the two acquisitions ?
1. Use the Merge Error Vi and send error wire to both Start (IMAQ and DAQ) VIs.
2. Use Notifiers. Here I generate a notifier and wire "wait on notification" to both Start VIs ?
Which is better ?
(C) Is there a better way than this ?
Any and all help appreciated.
thanks
gvstemp
PS: Only reason I am posting in 2 forum sections is to get wider audience.
Thanks.
06-06-2011 06:16 PM
Hi gvstemp,
For those who are interested, this question was addressed on gvstemp's other post
Good luck and let us know if you have any more questions!
