Machine Vision
Can I use the 1428 card with a Dalsa Spyder3 color 4k camera?
Here are the camera specs:
Part NumberSC-30-04K80
Resolution4096 x 2
Total Data Rate80 MHz
Max. Line Rate9 kHz
Pixel Size10 µm
Number of Camera Taps3
Output FormatCamera Link Base
Will this work with the 1428 or do I need to go to the 1429?
(3,175 Views)
Assuming it is Camera Link compliant, it should work fine with the 1428. You'll note the 1428 is Camera Link Base or Medium.
https://www.ni.com/en-us/support/model.pxi-1428.html
Jeff | LabVIEW Software Engineer
(3,157 Views)
