Machine Vision
Axis Camera
I am trying to acess an Axis 207MW network IP camera and i can't seem to figure out how to communicate with the camera. I know that it is possible because i saw a high school use this camera type for FIRST robotics. Labview provided them with the files to do it, i do not have these vi's. Right now i'm just using linux command called wget to get the image from the IP address. However, this is very slow and delayed. Can anyone explain to me how to better communicate with my camera? Thank you.
-CRBreingan
Message 1 of 17
(9,761 Views)
Hey Crbreingan,
The vi's that were used in the FIRST robotics competition were in a library (vi.lib) that was specifically written for interfacing with that particular camera. The vi's themselves most likely used TCP/IP commands to capture from the camera. So it is certainly something that could be accomplished through normal LabVIEW tools. However, this particular vi library is only available through the first robotics competition. Unfortunately, this particular vi library is not something that can be directly downloaded from National Instruments. If you have access to the startup CD's shipped with the FIRST robotics competition, that might be your best bet for that vi library. A popular forum for members of the FIRST robotics compitition is Chief Delphi -forum. Perhaps you could find some more support for that particular camera and the vi library there.
Hope this helps.
-Ben
Hope this helps.
-Ben
WaterlooLabs
Message 2 of 17
(9,747 Views)
Axis provides a SDK for this purpose. After you download and install this SDK, you can see Axis MediaControl in ActiveX Container in LabVIEW, which you could use to access the camera.
Message 3 of 17
(9,712 Views)
Yea, i've found the sdk. I'm using it now. Do you know what method to use in order to get the image? Every time i try to use the getCurrentImage method it freezes and i have to crash labview.
Message 4 of 17
(9,701 Views)
Hi all,
I need to creat several ROIs into a flow of images obtained by using PCO sensicam CCD in order to obtain the mean intensities of different parts. In this way, I can compare the inteansities of different parts in those of images as a function of time. Thanks!
Message 5 of 17
(9,697 Views)
Use the Media URL property to set what kind of video stream you want to get,and then method Play to activate the camera,and then use the get current image.
Message 6 of 17
(9,691 Views)
Yes, thanks guys. But i've tried that. I set everything up and i use the media url and all of that. But when it gets to the getCurrentImage call it just stops. It will not continue and even if i hit the stop button it won't stop. I actually have to go into task manager and end LabView before it will stop. I am running 64-bit vista. I heard somewhere that the AMC stuff doesn't like vista. Has anyone else experienced this problem?
Message 7 of 17
(9,655 Views)
So I still can't seem to get it to work. I got it to stop crashing the computer. But i still can't seem to get an image to display in the activex container. I am using the property node to assign values to: AutoStart, mediaUsername, MediaPasswrod, MediaURL, and MediaType. Then i call play from invoke node thingy. But i still can't get an image.
Can anyone please point me in the right direction? Thanks.
Message 8 of 17
(9,618 Views)
Accepted by topic author Crbreingan
The attached VI is for recording the stream for 5 seconds. It works for me in Windows XP...
Message 9 of 17
(9,602 Views)
Thank you so much! It worked for me too! I realize now that i was putting in the wrong url. Thanks again!
Message 10 of 17
(9,589 Views)
