Machine Vision
Can I write my own IMAQ Extract Buffer to use ippsMalloc?
I am using the Intel IPP library for fast image processing. I would like to avoid the need to copy the data obtained with IMAQ Extract Buffer into a new buffer created with ippsMalloc. Is it possible to write my own IMAQ Extract Buffer code that extracts into an ippsMalloc'ed buffer?
And a more general labview question: if I allocate an array externally in a dll how do I tell labview the size of the array? Right now I create a labview array of the right size, pass that to the C  code as a pointer and just replace the pointer in the C code. This works, but is extremely ugly of course and is a memory leak. Is there a better way to do that?
(3,640 Views)
Hi Dixie,
In the following link, you can find more info about allocating memory.
http://digital.ni.com/public.nsf/allkb/7253D2F0D91F68058625752F005AB672?OpenDocument
Bas
(3,495 Views)
Long time ago I had a problem which looks similar to yours - in my case dealing with a framegrabber sdk which had separate functions for allocating image buffers and storing images, referencing to the buffer pointer. The bottom line was that I was indeed able to conceive a neat hack, but that relied on the undocumented API of labview, and ended up working only in labview 7.1. If relevant, the thread is this one.
Enrico
(3,416 Views)
