Machine Vision
Invalid xml in matlab with IMAQdx
I am trying to interface with a GigE camera (SVS-Vistek svs4021) in Matlab 2009a, but I keep getting InvalidXML errors when I open the camera.  My goal is to create a .NET dll wrapper for the IMAQdx controls that will Open, Grab, and Close the camera.
Here's my progress so far:
 - Installed Intel PRO/1000 GT card.  Installed NI GigE driver.
 - Connected to camera in MAX.  This worked.  I could acquire images, change shutter times, etc.
 - Wrote a .NET dll and test program in C#.  This also worked.  I could acquire images and copy them into an array.  See below.
 - Loaded .NET dll in Matlab (using NET.addAssembly).  I could not get an image.  More investigation showed that I was getting error 1074360291, Unable to load camera's XML file.
I admit, writing .NET wrappers for .NET dlls is redundant.  I had to do it in the past for a non-.NET dll and now my Matlab code expects it.  I tried loading NationalInstruments.CWIMAQdx.Interop.dll directly into Matlab but I had errors running CameraOpen().  I have been trying to avoid using Matlab's Image Acqusition Toolbox.  It costs $1000 and I didn't want to rely on the 30 day trial.
Since the C# code works, it must be something simple like incorrect dll referencing or directory.  Does anyone have any ideas?  Is there some sample Matlab code for doing this?
Ryan
Here's a C# code snippet from my .NET dll:
         public void Connect()
            CWIMAQdx.Error Status;
            Status = CWIMAQdx.OpenCamera("cam0", CWIMAQdx.CameraControlMode.Controller, out sId);
            Console.WriteLine("Opening Camera - " + Status.ToString());
            MessageBox.Show("Opening Camera - " + Status.ToString());
            Status = CWIMAQdx.ConfigureGrab(sId);
            Console.WriteLine("Configure Grab - " + Status.ToString());
            MessageBox.Show("Configure Grab - " + Status.ToString());
(I use the MessageBox so I can see what's happening in Matlab.)
(6,027 Views)
Hi rkruse,
What version of IMAQdx are you using? I would suggest making sure you have updated to the latest. What OS are you running?
I would be interested in making sure all the various DLLs that load the XML file are being loaded from the proper place. It is possible that MATLab might have some similar named DLLs that are conflicting. If you could download a utility such as "Listdlls" (http://technet.microsoft.com/en-us/sysinternals/bb896656.aspx) and have it show the list of DLLs and paths loaded by the MATLab process when this fails it should tell us if the correct DLLs are being loaded. You should see a group of files loaded from a path such as: C:\Program Files\National Instruments\NI-IMAQdx\GenICam\bin\Win32_i86\GenApi\Generic.
Another possibility is that MATLab is doing some manipulation of its thread's acesss to the file system and is preventing the thread calling into our library from writing to disk. When the camera is opened our driver will attempt to download the XML file from it into a path such as: C:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQdx\Data\XML. Check if there is an XML file downloaded at this path that appears to be from your camera.
Eric
(6,021 Views)
Hi Eric,
Thanks for the response.  According to MAX I'm using IMAQdx version 3.1.2.  According to the forum posts this should be sufficient to avoid known IMAQdx problems.  However, Visual C# says that C:\Program Files\National Instruments\NI-IMAQdx\dotNET\Assemblies\Current\NationalInstruments.CWIMAQdx.Interop.dll is version 3.0.0.0.  I don't know if those numbers should agree.  I'm running Windows XP 32 bit.
I ran Listdlls after starting Matlab and after trying to access the camera.  Here are the added assemblies:
 0x09770000  0x7e000                   C:\Program Files\MATLAB\R2009a\bin\win32\dotnetcli.dll
  0x0a5a0000  0x46000   2.00.50727.3053  C:\WINDOWS\system32\mscoree.dll
  0x7c4c0000  0x7d000   8.00.50727.3053  C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\msvcm80.dll
  0x0b850000  0x590000  2.00.50727.3082  C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
  0x1e010000  0xaf7000  2.00.50727.3082  C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\6d667f19d687361886990f3ca0f49816\mscorlib.ni.dll
  0x0f7c0000  0x5b000   2.00.50727.3082  C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
  0x1f310000  0x785000  2.00.50727.3053  C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\80978a322d7dd39f0a71be1251ae395a\System.ni.dll
  0x64890000  0xf1000   2.00.50727.3053  C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Configuration\b82c00e2d24305ad6cb08556e3779b75\System.Configuration.ni.dll
  0x637a0000  0x536000  2.00.50727.3082  C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\773a9786013451d3baaeff003dc4230f\System.Xml.ni.dll
  0x0f920000  0x8000    1.00.0000.0000  C:\users\Ryan\Camera Testing\GigELibrary.dll
  0x0fa70000  0xc000    3.00.0000.0000  C:\WINDOWS\assembly\GAC\NationalInstruments.CWIMAQdx.Interop\3.0.0.0__4544464cdeaab541\NationalInstruments.CWIMAQdx.Interop.dll
  0x0fb90000  0x80000                   C:\WINDOWS\assembly\GAC\NationalInstruments.AxCWIMAQControlsLib.Interop\8.5.0.0__4544464cdeaab541\NationalInstruments.AxCWIMAQControlsLib.Interop.dll
  0x0fc10000  0x320000  8.05.0000.0001  C:\WINDOWS\system32\cwimaq.ocx
  0x6c400000  0x45f000  8.05.0001.49152  C:\WINDOWS\system32\nivissvc.dll
  0x74c80000  0x2c000   4.02.5406.0000  C:\WINDOWS\system32\OLEACC.dll
  0x76080000  0x65000   6.02.3104.0000  C:\WINDOWS\system32\MSVCP60.dll
  0x73dd0000  0xfe000   6.02.4131.0000  C:\WINDOWS\system32\MFC42.DLL
  0x5edd0000  0x17000   5.01.2600.5512  C:\WINDOWS\system32\OLEPRO32.DLL
  0x3fde0000  0x441000  4.05.6001.22159  C:\WINDOWS\system32\Msi.dll
  0x1fca0000  0x3a3000  8.05.0001.49152  C:\WINDOWS\system32\nivision.dll
  0x20050000  0x4ce000  2.00.50727.3053  C:\WINDOWS\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
  0x209f0000  0x15e000  3.01.0002.49153  C:\WINDOWS\system32\niimaqdx.dll
  0x64000000  0x55000   2.256.0003.0001  C:\WINDOWS\system32\NIPALU.dll
  0x64500000  0x6000    2.256.0003.0001  C:\WINDOWS\system32\nipalut.dll
  0x0faf0000  0x7000    2.256.0003.0001  C:\WINDOWS\system32\NIPAL32.dll
  0x6ff20000  0x7b000   7.10.3077.0000  C:\Program Files\MATLAB\R2009a\bin\win32\MSVCP71.dll
  0x23e40000  0x16f000  1.00.0001.0003  C:\Program Files\National Instruments\NI-IMAQdx\GenICam\Bin\Win32_i86\GenApi_MD_VC80.dll
  0x23fc0000  0xb000                    C:\Program Files\National Instruments\NI-IMAQdx\GenICam\Bin\Win32_i86\MathParser_MD_VC80.dll
  0x23fe0000  0xd000    0.00.0000.0003  C:\Program Files\National Instruments\NI-IMAQdx\GenICam\Bin\Win32_i86\GCBase_MD_VC80.dll
  0x235c0000  0x188000  2.00.50727.3053  C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\3da96ee075bab9202626ae44c18d226c\System.Drawing.ni.dll
I'm not sure what this means.  The windows assembly cache is pointing to the right CWIMAQdx.Interop dll.  Everything else is greek to me.
I have tried deleting the XML file from C:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQdx\Data before - MAX always recreates it.  My C# code also creates the XML file.  Matlab does not create the XML file.  It looks like this is the problem.  Is there a way to force the XML file to be written to a specific place?  Or a way to tell IMAQdx where to look for it?  If I need to talk to the MathWorks people, how should I describe the problem?
Ryan
(6,019 Views)
rkruse,
I don't see in there listed Xalan-C or Xerces-C, two components that are used to parse the XML file. Can you see if they appear anywhere else in the list? It is possible that MATLab loads its own copy that is not compatible.
Eric
(6,016 Views)
That's what I get for not including the entire DLL list!  Matlab loads xerces earlier.  I can't find a reference to xalan.
0x78df0000  0x1c2000  2.07.0000.0000  C:\Program Files\MATLAB\R2009a\bin\win32\xerces-c_2_7.dll
Ryan
(6,013 Views)
Accepted by topic author rkruse
Hi Ryan,
Ah, that's the problem... If you upgrade to a later version of IMAQdx it should fix your problem. Basically we use a common GenICam component (all GigE Vision software vendors share this component) that itself relies on Xerces. The older versions of GenICam were using a not-so-uniquely-named version of Xerces and so it had the potential to conflict with other copies loaded in the same process that were compiled with different compilers/settings. The new versions of IMAQdx use a newer version of GenICam that uses more uniquely named copies of Xerces that should not conflict.
I'd suggest updating to the 3.2 version here:
http://joule.ni.com/nidu/cds/view/p/id/1099/lang/en
Eric
(6,010 Views)
Eric,
That did it!  Now Matlab creates the XML file in the right place and I can acquire an image.  Thanks for your help.
Ryan
(5,982 Views)
