Machine Vision
Can NI Vision Builder compatible with Euresys grablink expert 2 card?
Hi All,
Do anyone of you know how to make below combination work?
Acq card: Euresys Garblink Expert 2
Software : NI Automated Vision Builder.
(3,072 Views)
There's no built in steps to work with 3rd party cards. You can either:
1 - use an NI frame grabber and use the existing high level steps to acquire/trigger from the camera. Is there a reason you can't use NI framegrabber?
2 - use the Vision Builder AI SDK to create your own custom step using Euresys API. Here's a forum post for some resources to do this...not sure if any one has done this already yet though:
http://forums.ni.com/t5/Machine-Vision/Euresys-Picolo-image-acquisition-and-LabVIEW/td-p/652066
Hope this helps,
Brad
(3,067 Views)
