Machine Vision
Vision acqusition software lisence Problem ????
Hello, Everyone
I Have LabVIEW 2009 with all development kit
I programmed an application (I use  IMAQdx in that application ) then I build application ((application EXE, then I build Installer for that application)).
I take that Installer and I setup it in another PC,
But it cry for two lisence (Vision development module $ Vision acquisition software)
why it cry for that lisence ? if I have it and deploy the application from my PC which have all lisences for Kits
Thankyou
Alzhrani
(3,798 Views)
The licensing for the Vision tools and software are for a single PC.  When you install it on a new PC, you must purchase new licenses for the new PC.  The good news is that the Vision deployment module license includes a license for the Vision acquisition software.
Bruce
Bruce Ammons
Ammons Engineering
(3,796 Views)
Accepted by topic author Al-Zahrani
Hello Al-Zahrani,
Bruce is correct.  You will need a NI Vision Run-Time License on the target computer since your application uses functions from the Vision Development Module.  I would recommend taking a look at our KnowledgeBase article about Licensing National Instruments Vision Software.  For information on pricing I would recommend looking at the NI Vision Development Module product page, specifically the "Related Software Add-Ons" at the bottom of the Pricing tab which lists the price for the NI Vision Run-Time License.
David A
(3,787 Views)
Hello, Bruce Ammons & Dacid A
Thank You for your replies , I understand that know.
I have to buy lisences.
Best Regard
Alzhrani
(3,769 Views)
