Machine Vision
Can any one suggest me the proper lens for IEEE 1394 Basler A601F
Dear all,
I got IEEE 1394 Basler A601F camera to acquire images using Ni Vision Software. But when I am trying to acquire images from that camera I am not at all getting the image, just iam getting some noise. And then I came to know that it requires the proper zooming lens, so I request to all of you please suggest me the proper lens for that camera.
Camera specifications are 640x480, 60FPS.
Thanks and Regards
Giridhar Yadav
(3,719 Views)
Please give us some details like the object u want to view.The size of it.Do you require any measurement.What is the optimum working distance etc.
(3,714 Views)
Dear sir,
I am going to acquire image of an analog meter (Tachometer), And optimum distance may be 10cm.
(3,706 Views)
A 25 mm lens with manual adjust of iris should work
(3,690 Views)
Thank you muks for your post.
For further information on calculating focal length, please take a look at the following KnowledgeBase: Calculating Camera Sensor Resolution and Lens Focal Length
Thanks!
--Michelle
(3,665 Views)
