Machine Vision
Can i use PCI-1411 to trigger NI 5112 to capture YUV vdieo wave of DVD sync?
Dear DFGray:
Thanks a lot for your help! But i have another question. I have a PCI-1411 ,i can use this card to trigger NI5112 to capture a line signal of CVBS output of DVD. And i can see in the graph just a line's wave. But if i seems that PCI-1411 cannot trigger the YUV output.The wave display still moves quickly,not just a line signal. Can i use PCI-1411 to trigger NI5112 to capture YUV output sync?
(2,937 Views)
Hi
Unfortunately the 1411 does not have a RTSI bus on it as the 5112 does. This means that you would have to make an external connection from the 1411's DIO/Trigger pin to the trigger pin of the 5112. You can then use the IMAQ Generate Pulse.vi in LabVIEW (or the equivalent function in the language you are using) to get the IMAQ card to generate a pulse on a particular condition i.e. Frame start. You can then pick this up on your 5112 as a start trigger to begin its acquisition. Good luck
(2,937 Views)
