Machine Vision
Why am in not getting a picture in LabVIEW?
The problem that I am having is that I get a picture in MAX but I do not get a picture in LabVIEW. I can't even get any information comming in on the U8 pixel readout. Nothing seems to come in. I don't know why. I have a KLI-2113 Tri-linear image sensor. It is a line scan camera. I can see that the IMAQ board is doing something because if I don't have it on and I try to start the VI "Acquire Image and Save Pixels Without Vision.vi", I get an error, no external pixel clock message. I know that it recognizes the board. I don't know why I get an image in MAX but not in LabVIEW. Can anyone help me out?
Brian
(3,386 Views)
You mentioned that you are able to acquire images in MAX, but not LabVIEW. What type of images are you looking at? Are they 8-bit or 16-bit? The issue may be that the image comming in from your camera is 16-bit, so no info would be displayed for the U8 (8-bit). Try the attatched example and see if you have any better luck- It allows 16bit images as well. If your image comming in is 12, or 10 bits, it is still stored as a 16bit image, but it is stored as the lower bits, so it may be necisarry to shift the bits as well.
(3,386 Views)
I love you man, Finally, after 3 months I am able to see a picture using LabVIEW. I really appreciate your help, thanks a million. Also, you said, "If your image comming in is 12, or 10 bits, it is still stored as a 16bit image, but it is stored as the lower bits, so it may be necisarry to shift the bits as well." How do I "shift bits"?
Thanks again,
Brian
(3,386 Views)
If you buy the vision toolkit, there are functions that will do this for you, but otherwise, you can look at the code I sent you. The function you want to look at is called Display Image. In this function it treats the incomming image differently depending on if it is an 8bit or a 16bit image. If it is a 16bit image, it use the # to shift input to logically shift shift each pixel value before truncating to 8 bits. so if your binary data looked like this:
00000011 10100111
it could shift left by 6 to get this:
11101001 11000000
and then trucate the lowest 8 (which is the least signifigant data) bits to finally output:
11101001
(3,386 Views)
