Machine Vision
Can i use vision assistant for creating C code ?
on the vision assistant tool menu there is option ' creat C code ' should i use this option for converting my labview code into C   ? (first run my labview VI in vision assistant and then convert )
(5,231 Views)
Its not conversion LabVIEW Code to C Code. This tool will convert Vision Assistant Script to the equivalent C Code. You can also convert same script to LabVIEW Code, and this LabVIEW Code will be functionally the same with C, but there are no tools available for LabVIEW to C conversion.
Andrey.
(5,229 Views)
Hi amirheh,
Thank you for contacting National Instruments. As Andrey correctly points out, there is no way to convert LabVIEW Code to straight C code. This is due partly to the way LabVIEW compiles in that it compiles straight to machine code and doesn't go through an intermediatory language.
There are a couple of forums that are linked here and here that give a bit more details on LabVIEW and C conversion and I would recommend looking at these. Generally speaking, there is no performance difference between a well written LabVIEW program and a C program.
Can I enquire why you want to generate C code? Generally speaking the best method of trying to bring LabVIEW code into a C-based language is to build the LabVIEW code into a DLL and call this within your C code.
I hope this helps,
Many thanks,
Andrew McLennan
(5,209 Views)
As Anderew mentioned, Good LABVIEW coding could yield a narrow results to C (but not identical to). You may read this article:
Can LABVIEW C?
Do you use LabWindows/CVI?
Cheers
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(5,174 Views)
Actually i have a cmu cam and i want to program my LabVIEW code into it,I don't know how ?
can anyone help me ?
(5,121 Views)
If under "cmu cam" you mean CMUCam3, then probably you can develop LabVIEW code with NI LabVIEW Embedded Module for ARM Microcontrollers  (but I'm really not sure).
Andrey.
(5,117 Views)
HELLO,
I create a script under vision assistant after that i convert the script  with image control under Labwindows/CVI on C code ,
the C preject creating didn't shows the windows of selecting the control and indicator to create on the front panel.
I found just  :
- main code.c
- processing.c
- processing.h
- NImachineVision.c
- nimachinevision.h
But not an interface.uir, they just apear the window to aploed  the image but the precessing on this image dont apear , i can just display image without processing
Which file will i modify? what i have do on next step to correct
Please help me.
Best Regards.
(3,461 Views)
