Machine Vision
Error in "IMAQ grab setup.vi"
Hello
I'm using labview 8.0 (upgrade from 7.1) and NI IMAQ 3.5 and NI PCI-1411.
I'm trying to acquire images. If i use MAX everything works fine, but when i try to use vi in IMAQ (pallete), some vi give error like the one in the image below.
Can anyone help me?
(4,418 Views)
Hello Cmsp,
If you speak French, please see the link below that will help you to solve the problem :
http://forums.ni.com/ni/board/message?board.id=170&message.id=134203&requireLogin=False
If not, please reply to my response to explain in english how to do.
Sanaa T
Sanaa T.
National Instruments France
(4,402 Views)
Thanks for the answer
I understand french, but i still have the same problem.
I dont find the directory C:\Program Files\National Instruments\NI-IMAQ for IEEE-1394\Data , but i find C:\Program\National Instruments\NI-IMAQ\Data, i delete the files but, nothing. The problem continues. Can you help me?
(4,393 Views)
Bonjour,
Pourriez-vous intégrer la partie du code ci-joint pour changer dynamiquement la "Reference Voltage Value"?
Cordialement,
Sanaa T
Sanaa T.
(4,372 Views)
Hello Sanaa T
Thanks for the reply
The problem was solved, but i have to modify the code you sent, because my labview cant find the vi IMAQ WindDraw
Merci.
(4,368 Views)
Hi, I am using Labview 10 and I am facing the  problem in " IMAQ Grab setup.vi". They showed possible reason that the requested acquisition window may be invalid.
How did you solve your problem?
(3,113 Views)
