The pattern matching routines work much better on grayscale images with high contrast. You might get it to work by scaling your binary image from (0-1) to (0-255).
I would seriously consider using the NI OCR package if possible. It will be much faster than the pattern matching routines, and it will require a lot less work.
Bruce
Bruce Ammons
Ammons Engineering
