Machine Vision
Can pattern matching be applied to binary images?
I am developing an OCR using pattern matching.
I applied thresholding to an image containing numeric value. It changed to binary. Now i find that it is not able to apply pattern matching to learn digits.
Does it mean that we need 8bit gray images only for pattern matching?
(3,291 Views)
The pattern matching routines work much better on grayscale images with high contrast. You might get it to work by scaling your binary image from (0-1) to (0-255).
I would seriously consider using the NI OCR package if possible. It will be much faster than the pattern matching routines, and it will require a lot less work.
Bruce
Bruce Ammons
Ammons Engineering
(3,291 Views)
