Machine Vision
Can't get correct Binary Image from video
I created a small VI that takes the first frame of a selected avi file, converts it into gray scale, and then attempts to convert the gray scale image into a binary image.  For some reason, the binary image just comes out all black (despite the gray scale image showing a very bright tennis ball).
Here's a picture of my block diagram and front panel (with results): http://imgur.com/QxunT
I also attached my vi and video.  Any help is greatly appreciated, of course.
(3,234 Views)
Accepted by murrdpirate
The background gray value is something around 30...50 and ball is 150..220. So, try to use Range 100,250 in IMAQ Threshold instead of 0,1 - you will be surprised.
Andrey.
(3,226 Views)
You are exactly right.  I originally thought that was how it was supposed to be, but every reference I saw about creating binary images said to use 0 and 1.  Thanks!
(3,224 Views)
Don't forget to use the Binary palette on your image display. This allows to see in black and red your binary image, otherwise you will see no visible difference between 0 and 1.
(3,211 Views)
