Machine Vision
Can't get full image using NI-1433 from a dual-line line scan camera link camera.
Hello every,
I am working on a project using a camera link line scan camera and NI-1433 frame grabber. I tried to generate camera file and make them work with each other.
My problem is I can't get full image from the frame grabber or the camera. I took a snapshot and I can only see half of the object. My camera is set to work at 8-bit  2 tap, and the frame grabber is set to 2tap left and right.
I almost tried every possible combination of camera output mode and frame grabber mode and I found that when I set camera to 8-bit 4tap and frame grabber to 1tap I was able to get full image and everything seemed like working fine.
Can anyone explain why this happened? I want to make sure the camera can work with frame grabber before I move forward.
Below is the frame grabber mode options. Interlaced modes absolutely can't work. I guess the only options are 1 tap or 2 tap left/right.
(3,811 Views)
Hello Ryyyyan,
If you configure your camera to use 8-bit 1tap and the frame grabber to 8-bit 4tap as well, can you see the full image? What Camera are you using?
j_bou
(3,767 Views)
