Machine Vision
Can the locaton of the Windraw box be changed
I'm using IMAQ Windraw to bring up an image, however the first time it runs it places the image in the middle of the screen which covers the indicator.
I know it can be moved with the mouse but this is a turn key system i.e. the user has no mouse or keyboard access
(2,949 Views)
Use WindMove in the display palette before you use WindDraw the first time. This will set the position of the upper left corner of the window.
Bruce
Bruce Ammons
Ammons Engineering
(2,949 Views)
