Machine Vision
Cannot create a control or indicator for an Image Display refnum in LabView
I need to pass a refnum to an Image Display control, but find that I cannot create either a control or indicator for such a refnum.  I can create the refnum with no problem, and when I right-click on the refnum I am given the options to create a control or indicator; however, when I select either of these options no control or indicator is created.
(5,062 Views)
I figured out how to do this not too long ago.  Create a refnum control for practically anything on a front panel.  Drag an Image Display control and drop it on the refnum control.  The refnum control magically turns into an Image Display refnum!!
I recommend making this a strict type def, then using the type def anywhere you need it in your program.  When I upgraded from Vision 8.5 to 8.6, there was a glitch in my program that crashed it until I recreated my refnum from scratch.  I had to replace it in several places in my program.  Being able to recreate it just in a type def would have made life simpler.
Bruce
Bruce Ammons
Ammons Engineering
(5,057 Views)
Thanks for the help Bruce.  I tried this, and it doesn't quite work for me.  The dragging and dropping works as expected.  However, when I try to use the resulting control, I get the following error:
Compiler Error: Control not in owning dco, ddo=0x8C58020
This is true independent of trying to hook it up; i.e., if I just create it, and then try to turn it into a strict typedef as you suggested, the .ctl itself doesn't compile, and I get the error shown above.  I am using LabView 8.5 right now.  You mention having to recreate your refnum from scratch - could you elaborate a bit on that?
Greg Flynn
(5,042 Views)
I thought I described exactly how I created the control.  Perhaps I left out one step that I have forgotten.
I have attached my type def control.  It is LV 8.5.  Hopefully it will work for you.
Bruce
Bruce Ammons
Ammons Engineering
(5,040 Views)
Hi Bruce,
Thanks again.  The control that you sent me looks and acts just like the one I created using your instructions, so I guess they were clear.  As soon as I place the control in a VI the VI breaks, and I get the compliation error shown in my previous post.  If I simply  open the control, modify it (e.g., by changing the label), and then try to save it it fails to compile and I get the same error message.  I think we can safely conclude that my LV 8.5 behaves differently than yours.  Are you running on XP or Vista?
(5,038 Views)
Accepted by gflynn
I am running XP.  I installed Vision 8.6 at one point, but had to uninstall it because it corrupted this control.  I don't know if it affects this type of control on a lower level.
You could probably do this the hard way using a workaround.  Convert your reference to a variant or flatten it to a string or typecast it to an integer - whatever LV allows.  In the subvi, convert it back to a reference.
Bruce
Bruce Ammons
Ammons Engineering
(5,034 Views)
Hi Bruce,
Thanks one last time.  Converting to variant works.  I'm on Vista, which has been a constant source of problems.  Don't know if that's the difference in this case.  I too have installed, and then uninstalled LV 8.6, in my case because I was using a driver that was incompatible with 8.6.  So, I suppose it's possible  that there is some vestige of 8.6 lingering on my computer causing problems.  In any event, I appreciate the work-around.
Greg Flynn
(5,025 Views)
