Machine Vision
Changing Camera attribute From Front Panel
Dear Team,
I am using Basler GigE camera with VBAI. In my application I have to change the Exposure Value from front panel.
Please suggest me the way to do that. I already went through some discussion here and found it is for Smart camera where there is a tab "Advanced" under which this option is available.
But I could not find this option in my case.
(3,665 Views)
Accepted by JN_23
For GigE cameras, use the Read/Write Camera Attribute step. Since the exposure time can be set without stopping the acquisition, you can use the "Don't stop acquisition" mode and associate the attribute with a previous result to change the value.
Hope this helps,
Brad
(3,552 Views)
Thanks Brad.
It worked for me.
(2,761 Views)
