Machine Vision
Changing Interface Names of FireWire Cameras in MAX
Hi Guys :
      I ask the same problem five years ago (see the first link , ohh , can't image that's five years ago , everything changes ...... )
and fixed in following thread(windowxp based ), but now i met the same issue at Win 7 , can't find the config file under
      ‹root directory›\Documents and Settings\All Users\Shared Documents\National Instruments\NI-IMAQdx\Data
      http://forums.ni.com/t5/Machine-Vision/Camera-ID-Settings-Problem/m-p/906249#M22962
      http://digital.ni.com/public.nsf/allkb/61405DCC1A09CDE686256F00005AA2B5
      http://digital.ni.com/public.nsf/allkb/AD1041C9B4B27240862570DD0068605B
Thanksw
(5,562 Views)
Any feedback ?
(5,541 Views)
Hi adobefree,
The camera file needs to be in the data folder in order for it to work with the camera.  If it is not there, then it probably means it's not a default camera file that comes with our software and you need to get it separately.  You can create your own, or contact the manufacturer of your camera to see if they offer it.
Julian R.
(5,530 Views)
I can see the camera every time i open the NI MAX explorer , and i can see the settigns changes have been stored there , which means it already been a default camera .
But i just can't file the config file undet data folder , could you check what's the path of config file in WIN7 enviroments ?
(5,524 Views)
It is under the C:\Users\Public hierarchy.
Eric
(5,514 Views)
Accepted by topic author adobefree@gmail.com
I found them , thank you guys!
(5,495 Views)
