Machine Vision
Color verification of LED's, How to determine the correct standard illuminant
Hi guys, this is the scenario:
I need to determine LED colors with ( machine vision + LABVIEW).
LABVIEW allows me to sample the RGB value of a  picture and convert it into a point on the CIE xyY color space.
To get from here to the color of the LED, the method I have in mind is to calculate the gradient between the point obtained and the white point.
The question:
I am not sure which how to select the white point?   The standard white points that I can find on the internet are for objects reflecting the illuminant.
Where as in my case, the object of interest (the LED) emits light itself. I wonder how would this affect the selection of white point.
On the otherhand, I wonder if ambient lighting would affect the hue of the LED color sampled?
It would be greatly appreciated if anyone can help me  Smiley Happy
(3,751 Views)
Can u explain it in a better  way.I am not getting your point
(3,645 Views)
Yup it will affect the  not only hue but  luminance as well.Give a description of your setup and  the camera u r using or planning to use.
(3,644 Views)
