Machine Vision
how to decode infomation of IMAQImage type?
hi, now I need to get some infomation(eg. some digital value) from image data, but the image data is type of IMAQImage. IMAQImage is a type NI defined. How can i decode it?  Have anyone met this problem before? can you give me some advice? thank a lot!!
My hardware is PXI-1422, Software is labview8.2
(3,536 Views)
I dont get it. Did you try "image to array " function?  you can  then play around with the values
(3,533 Views)
thank you very very much!!
I tried the function you mentioned, and it works~
this is the first time I use vision moduler, and now I realize my question is a little bit stupid.
thank you for your advice, it's a great help to me~~~
(3,526 Views)
(3,526 Views)
