Machine Vision
Computer can not recognize PC-DIO-24 pnp
I was working with PC-DİO-24 pnp properly.But because of a sudden unknown effect computer started not to see this card.Although I tried to install it,nothing changed.the card might be damaged because of a short circuit.I it possible for me to repair it?
(3,162 Views)
Since this card is a DAQ card and not an IMAQ card, you may want to restate your question on thier forum. However, they'll probably tell you the same thing as me...go to ni.com/ask and see if there is anything you can do there to get the board working. If there is nothing you can do, then you may have to send it in for repairs. The engineers at ni.com/ask can help you with that as well.
Kyle V
(3,162 Views)
