Machine Vision
Configuring Dalsa Spyder3 (latest version) with MAX
Hi all,
I can't find how can I configure Spyder3 GigE cam from MAX to use an external trigger and external encoder for line rate.
It works with factory settings (internal line rate and programmed image size). Somebody can help me?? Max attributes are really hard to understand...Smiley Indifferent I'm getting mad...
Thanks in advance.
Vicente.
(3,539 Views)
The attributes you see in MAX are provided by the camera, not IMAQdx or MAX. What I think you meant to say is that the Spyder3's triggering settings are hard to understand, which I completely agree with 🙂
You'll likely have to contact Dalsa to determine how to configure the trigger in the exact mode you want.
Eric
(3,537 Views)
Thanks Eric.
Then, Max is already showing all camera attributes... really hard to understand.
Thanks!!
(3,532 Views)
I have the same problem. The extern trigger is working with spyder3 and Dalsa Quickcam.But with labview works only with internal trigger. I please let me know if you have an idea.
(3,374 Views)
