Machine Vision
Setting up environment for display cluster verification
Hello all,
I am starting with a fresh project which needs image acquisition and verification of different display clusters, having different sizes.
Firstly, I need to setup an ideal environment which would introduce minimal errors (like perspective error). I would be able to keep the camera mounted perpendicular to the display device. Apart from this point, what other points should I consider while setting up an environment for image acquisition? What points should I consider while building up a mounting structure for vision based inspection?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 1
(2,814 Views)
