Machine Vision
Confused by IMAQdx Extract Image
Using LV2015, I have a ring acquisition. It runs fine until the camera stops acquiring. This happens because it has a hardware trigger. When the test ends the camera stops receiving triggers. At that point I want the loop containing IMAQdx Extract Image to finish, but it doesn't. As best I can tell this is because I have that vi set to never time out.
I need it to never time out because when I start up the program the camera may not be acquiring.
So how do I tell it there are no more images coming and to move on so the loop can close?
 Hopeful this part of the diagram helps.
(2,346 Views)
You could stop or close the IMAQdx session, and that will unblock the loop.
(2,148 Views)
Hadn't thought of that. Might be a good idea. Thank you.
What I'm doing right now is applying a time out but using the buffer counter to tell me if the vi has timed-out. If it has, I just go around the loop again. I also note if any acquisition has taken place. That way, I can avoid a timeout before starting to acquire but permit a time out when the acquisition is complete and no more images are being received.
(2,067 Views)
