Machine Vision
Continuous image acquisition using vision builder
Hello, I am using NI 1744 and want to know how to acquire and save continuous images using Vision Builder. I am able to acquire and save a single image but cannot acquire continuous images.
Looking forward for your assisstance.
(4,001 Views)
Performing this task using MAX or LabVIEW is also acceptable. Please help.
(4,000 Views)
Accepted by Burki
Burki,
Are you trying to save the continuous images as a movie?  This is not supported in VBAI, however if you wish to snap continuous frames individually you can try editing your inspection state diagram to repeat your current inspection and transition to the stop step only after your current inspection has been performed a set number of times.
Isaac S.
(3,981 Views)
