Machine Vision
Contrast Enhancement
Is there any IMAQ VI that does contrast enhancement . I know in MATLAB , the command is imadjsut(), but using that script node with that command is a big problem. I could not find any VI that does that in LabVIEW vision toolkit.
So I want to know if anyone has done contrast enhancement on an image, and what vi or combination of VI he/she used.
Thank you.
(6,782 Views)
Hi Okogidi,
    NI IMAQ actually provides a very academic methods. Contrast enhancement involves "Distributing dynamic range all over the image". this is known as "Image Equalization". You can find this method as "IMAQ Equalize" under
Vision and Motion >Image Processing >Processing> IMAQ Equalize.
Image Equalization is not the only method for enhancing the image, but its power is in that it dynamically distribute the imtensity of the image . You may also consider using "Look up" method for specific enhancement. Please refer to "IMAQ concept Manual" for more information.
Message Edited by VBCoder on 09-09-2008 08:04 PM
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(6,780 Views)
Thank you VBCoder.
I am still a little bit confused, the IMAQ Equalize performs histogram equalization. Histogram equalization is  of course one way of enhancing an image, it redistributes the image gray levels.
Histogram equalization is one way of doing contrast enhancement . but it seens histogram equalization distributes uniformly.
Like in MATLAB, imadjust(image), and histeq(image) are two different algorithms.
The IMAQ Equalize like I said performs only histogram equalization.
(6,768 Views)
The function you are looking for is probably BCG Lookup.
You can also do it in a few steps manually.  Use Quantify Image to get the min and max values.  Use Image Subtract to subtract the min.  Use Image Multiply with the value 255/(max-min) to maximize the contrast.
Bruce
Bruce Ammons
Ammons Engineering
(6,761 Views)
works really nice, for some other application...
thanks
(6,286 Views)
I use 'Linear' operator in IMAQ MathLookup.  I also use a histogram display with cursors so I can specify the range over which to contast expand.
IMAQ BCGLookup.vi does not allow one to specify an interval range.
Late to the table here but this method had not been mentioned yet so figured I would mention it.
(5,952 Views)
