Machine Vision
Controlling frame rate and ROI on a ge680 using IMAQdx
Thank you, Here is the block diagram I've been using.
I'm not really sure how to post a screenshot so it shows here but I've attached a .jpg of it, as well as the actual file itself.
Edit: I noticed in the screenshot I left the case structure in "false", the true case simply takes the frames and adds them to an .avi
Message 11 of 12
(1,224 Views)
Accepted by topic author mr. smithers
Found the example "grab and scalable attributes" and its been working great! thank for your help!
Message 12 of 12
(1,205 Views)
