Machine Vision
Convert Contour to ROI
Hi Guys:
        I'm using IMAQ Extract Contour VI to get the contour points, is there anyway to conert thoese points to ROI , so that i can extract the
area from the image ?
Message 1 of 8
(6,991 Views)
What you probably want to do is create a mask from the controur.  This produces a binary image, with every pixel inside the contour receiving a value of 1, and everything outside receiving a value of 0.  Now you can take this binary image, and multiply it by the original.  The result image will contain only those pixels that are inside the mask.  All others will be 0.
If the original image is not 8-Bit, you will need to cast your binary image to whatever bit depth you need.
If you really need an ROI, you can use the Mask to ROI VI to get this.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
Message 2 of 8
(6,981 Views)
This can work for You:
This is good example about ROIs:
http://zone.ni.com/devzone/cda/epd/p/id/5249
Message 3 of 8
(6,978 Views)
Thank you guys for the great help!
Message 4 of 8
(6,971 Views)
Could you upload the vi you shows in attachement ?
i can't find it from the examples
Message 5 of 8
(6,969 Views)
I tried , seems like the ROI is invalid.
Message 6 of 8
(6,965 Views)
Message 7 of 8
(6,962 Views)
Thank you guys for the details and examples... It helped me a lot in my project...
Into the pursuit...
Maverick
Message 8 of 8
(5,789 Views)
